Chirpstack details
Specifying installation(s)
The Chirpstack integration is set up to handle connecting a single LoRa-sensor to one or more installations. This is done by adding a tag with the key lynx_client_ids
on the device. This is a comma-separated list of client-IDs in IoT Open that the device should send data to.
Specifying decoder by name
It is possible to specify a specific named decoder for a sensor in Chirpstack. This might be needed if sensor type can not be determined automatically. To do this, add a tag called lynx_decoder_name
on the device in Chirpstack.
Example
This is an example of a device with the decoder name tag set.
